Content originally posted in LPCWare by kemes on Tue Apr 09 22:10:26 MST 2013
Hi to all
I am using LPC11U37 with LPCXpresso v5.1.2 [Build 2065] [2013-02-20]. Due to the fact that some RAM is reserved to USB, there is a way to force assigning a buffer to USB RAM ? I saw that I should enable the clock setting USBRAM bit in SYSAHBCLKCTRL.
How can I force some data to be allocated in this ram ?
thanks
