Content originally posted in LPCWare by nsacks on Mon Mar 25 09:17:26 MST 2013
Hello all,
For reference, I am working with LPC4330Xplorer board, trying to access the M4 core. I am also working in Linux.
I have been successful in downloading the Virtual Serial example project, however, when I go to test the echo functionality I am given the following script:
[FONT=Courier New][SIZE=2]
[ 183.818893] usb 2-4: >config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 255, changing to 11
[ 183.818906] usb 2-4: >config 1 interface 1 altsetting 0 bulk endpoint 0x3 has invalid maxpacket 16
[ 183.818914] usb 2-4: >config 1 interface 1 altsetting 0 bulk endpoint 0x82 has invalid maxpacket 16
[ 184.144427] usb 2-4: >New USB device found, idVendor=1fc9, idProduct=2047
[ 184.144438] usb 2-4: >New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 184.144445] usb 2-4: >Product: LPCUSBlib CDC Demo
[ 184.144451] usb 2-4: >Manufacturer: NXP
[ 184.157154] usb 2-4: >can't set config #1, error -32
mtp-probe: checking bus 2, device 2: "/sys/devices/pci0000:00/0000:00:13.2/usb2/2-4"
mtp-probe: bus: 2, device: 2 was not an MTP device[/SIZE][/FONT][SIZE=2]
[/SIZE]
I was wondering if anyone new a solution to the problem, as I have exhausted all ideas. I have configured all linked projects correctly, but I think there might be a problem with the descriptor file, but I am not sure what to do with it.
Thanks!
