Content originally posted in LPCWare by amendae on Sun Jul 18 20:08:56 MST 2010
Quote: domen
It'd only confuse you, because some parts were rewritten etc.
I just cut out the serial.c code, and filled the outgoing circular buffer in main (while(1)) loop.
Well, actually with CDC, I personally barely reach 40KB/s...which is slower than the 64KB/s that HID brings out of the box :( I might be doing something wrong. I would also appreciate some guidance here, especially if someone managed to reach 900Kb/s.
