lpcware
Usb cdc
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by maxlobovsky on Wed May 26 15:45:42 MST 2010
Does anyone have any example code that uses USB CDC to enable a virtual com port to the microcontroller itself, and not to its UART.  It is convenient to use a virtual serial port to talk to the microcontroller.  I know I can work from the example USB CDC code to do this, but I wanted to check if someone had done it first.
Max
Original Attachment has been moved to: 1100420_LPCXpresso.zip
