Internal Pull Up LPCXpresso 11C24
lpcware
Content originally posted in LPCWare by f_acosta on Mon Apr 07 17:17:09 MST 2014
Hi, I'm trying to deactivate the internal pull-ups from my LPCXpresso but I change the bit in the IOCON register and nothing changes.
This is my method :
LPC_IOCON->PIO2_2 &= ~(1<<4);
the User manual says that you must clear the 3:4 bits to deactivate internall pull ups.
And completely this is how I configure the GPIO
LPC_GPIO2 -> &= ~(1 << 2)                         //Set as output
LPC_IOCON -> PIO2_2 &= ~(1<<4);            //Deactivate pull up
IOCON reset state is as GPIO and Pull up activated
What's wrong?
Thanks for your help.
lpcware
Content originally posted in LPCWare by 1234567890 on Mon Jun 09 00:24:23 MST 2014
Quote:
What's wrong?
Probably you didn't set bit 16 (IOCON) in SYSAHBCLKCTRL.
