lpcware
ADC calibration
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Genesy on Tue Oct 15 06:22:02 MST 2013
in the datasheet of LPC11xx and other I read that ADC without calibration is affect by a total error of about 4 LSB.
How I can do an ADC calibration to make my ADC most accurate?
If I reduce my adc sampling rate will I be most accurate?
I looked that this value is bounded with CPU frequency with the following formula:
PCLK/(CLKDIV+1)
where CLKDIV is a 8bit field in ADCR register.
Since I work at 48 MHz and the maximum value is 256 CLKDIV the ADC minimum frequency is 187500 khz, is right?
Isn't this a limit?
Thank you very much
