Content originally posted in LPCWare by fumio yoshizawa on Thu Apr 10 22:51:13 MST 2014
I want to know about limit program size.
Because I met error at build phrase about this. (collect2.exe: error: ld returned 1 exit status)
Remove some routine and build I get this result.
text data bss dec hex filename
4764 4 448 5216 1460 RS486_t1.axf
My target board use LPC11U14(LPC11U14FBD48). (Flash 32kb , SRAM 6kb)
code_red info say.
the flash consumption of your application will then be text + data.
the RAM consumption of your application will then be data + bss.
I think still enough memory exist.
Please tell me about cause of the error.
Fumio Yoshizawa, from Japan.
