Content originally posted in LPCWare by dizgah on Sun Feb 28 22:08:41 MST 2016 Hi, Is this possible to integrating atom editor(Fantastic editor from github)or any other modern editor with lpcexpresso? WBR.
Content originally posted in LPCWare by miccio on Fri Mar 04 10:57:58 MST 2016 you can use LPCXpresso in headless mode and instruct atom's build engine to use it as your compiler. You could also simply use GCC ARM in your build config file, except LPCXpresso also updates your linker scripts and re-generates the makefiles hierarchy, but take this with a grain of salt.
The only missing feature would be trace and debugging. The latter can probably be solved with some other atom package, maybe look for GDB packages.
Content originally posted in LPCWare by vtw.433e on Mon Feb 29 01:38:39 MST 2016 LPCXpresso uses Eclipse. If there is an Eclipse plugin available, it should work
