lpcware
How can i change the MAC address in the ethmac.h
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by kuhan on Mon Nov 04 00:19:13 MST 2013
Hi Sir/Madam ,
   I am working on the easyweb example code . I have change my IP address accordingly to the ethernet board setting in tcpip.h . but i still cant load the webpage in my browser . I initially did not change the mac address in ethmac.h  and there is no compiler error . Now i have configured that MAC address in the ethmac.h  i face the following error .
../src/ethmac.c: In function 'Init_EthMAC':
../src/ethmac.c:208: error: 'BB' undeclared (first use in this function)
../src/ethmac.c:208: error: (Each undeclared identifier is reported only once
../src/ethmac.c:208: error: for each function it appears in.)
../src/ethmac.c:208: error: 'E7' undeclared (first use in this function)
Can you explain if i should use hexadecimal format when i configure the MAC. Is it possible to obtain a sample of the configuration .
