Content originally posted in LPCWare by blasiis on Wed Jul 21 05:37:48 MST 2010 I use LPCXpresso free with LPC1758 that have 512 KB flash and the limit of free compiler is 128K. I use the top flash sector (28 and 29) for store my data application like EEPROM. Whit debug when I restart the debug the value present in sector 28 and 29 dont change !! This is a free compiler limit or I must set a configuration project for erase all the flash ?
Content originally posted in LPCWare by blasiis on Wed Jul 21 06:22:29 MST 2010 Quote: CodeRedSupport Not automatically, but you can do it by pressing the "program flash" button on the toolbar.
Content originally posted in LPCWare by CodeRedSupport on Wed Jul 21 06:01:10 MST 2010 Not automatically, but you can do it by pressing the "program flash" button on the toolbar.
Content originally posted in LPCWare by blasiis on Wed Jul 21 05:44:41 MST 2010 Quote: CodeRedSupport The debugger only erases the flash (sectors) that it uses. Is possible to erase all the flash sector before program the code application ?
