Content originally posted in LPCWare by larryvc on Fri Apr 22 22:33:55 MST 2011
Hi GreenITguy,
Welcome to the forum.
Quite a few people, including myself, have installed and are running LPCXpresso on Win 7 64-bit without any problems. You should not have had to uninstall the DFU drivers to get up and running.
Just a few questions to get the pump primed for everyone.:)
Is Win7 running native i.e not on a virtual machine?
Is your USB port powered i.e. not on an unpowered USB hub?
Is your LPCXpresso1114 standalone or are you using it with an EA base board? If on a base board, the base board needs it's own power.
When you installed LPCXpresso were you an Administrator?
Have you tried a different USB cable?
That should be enough for now. I really need to write a script for this.:)
Answering these will help all of us understand what you are working with. We're all in different timezones and we come and go frequently.
Larry
