Thad Seeberger
Reset Problem - 9S12dp32
Discussion created by Thad Seeberger on May 21, 2008
Latest reply on May 22, 2008 by kef
Good day, I have a problem where code runs fine with P&E multilink connected under debugger. Also with multilink disconnected program will run when you exert an external reset. Problem is it wont run with internal POR reset. Where shoud I start to look where the problem is. Chip is 9S12dp32
Thad
Added p/n to subject.
Message Edited by NLFSJ on 2008-05-21 10:27 PM
