Content originally posted in LPCWare by nsalzman on Fri Sep 23 08:08:26 MST 2011
Okay, so I'm making some progress but I still can't figure out why projects are not importing correctly on a Windows XP machine.
I start up the IDE, create a new workspace, and import all of the projects from
C:\nxp\LPCXpresso_4.0.6_152\lpcxpresso\Examples\NXP\LPC1000\LPC17xx\NXP_LPCXpresso1769_MCB1700_2011-02-11.zip
I then navigate to the file timer\Debug\makefile or timer\Debug\timer.map and it includes references to files located at "D:\projects\lpcxpresso\(a bunch of other stuff). This matches up with what is in the zip archive before importing the project into the IDE.
So it appears like what is happening is that when the project is imported, it is not modifying the makefiles to reference the appropriate local file locations. On my computer where I have gotten everything working, the makefiles and .map files etc. all reference the appropriate locations.
So what is going on during the import, or what environment variables are missing that are causing this problem?
