lpcware
Write to Peripheral Registers
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Andreas Richter on Thu Jan 31 23:59:13 MST 2013
I'm rather new in the ARM-Cortex World, and I have a general Qustion for accessing Peripherals. Is it save to write to the same Peripheral register e.g. LPC_TIM0->MCR from both, an ISR and the Main program (both accessing different Bits of course). It would not be safe if the Compiler translates the modify instruction into:
- fetch value into register
- modify register
- write back register
I don't know if the ARM has the capability to mofify a memory value directly.
In that case it would be safe.
Regards Andreas
