Content originally posted in LPCWare by francisco.tortosa on Sun Mar 01 15:04:21 MST 2015
Hi R2D2.
I am scoping the signal at P2.10 and this pin (with a 10K Pull-up resistor to 3V3, with no more connections) is always low,
Regardless of the later configuration (input, output low, output high), sometimes I gain control with the debugger , sometimes (the most) not.
Thanks.
