Content originally posted in LPCWare by Muis on Wed Jul 22 04:37:26 MST 2015 If you use CRP to disable READ of the firmware, how can you send out firmware updates? Is it possible to encrypt them for example?
Content originally posted in LPCWare by TheFallGuy on Wed Jul 22 05:47:26 MST 2015 by writing code in your firmware that does the firmware update (by using IAP). Your code would need to do the decryption.
