lpcware
LPCOpen can't work with arm-none-eabi-gcc toolchain
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Max Chen on Fri Jul 04 20:27:02 MST 2014
Hi All,
I try to compile an example, periph_ritimer, from lpcopen by arm-none-eabi-gcc toolchain,  no any error and and axf file is generated.But when I download it in my LCP-LINK2(as an evaluation board), nothing happen. I have modify the code let the led blink and it work when I compile the code
with lpcxpresso, but same code no work when I use arm-none-eabi-gcc.
I also try to debug it with jlink, the code can run to while(1) in main, this may mean no interrupt happen when compile by arm-none-eabi-gcc.
The attachment is the makefile and ld script, please some one help me.
Thank you.
Original Attachment has been moved to: periph_ritimer_makefile.zip
