Content originally posted in LPCWare by pgr on Mon Nov 10 01:37:59 MST 2014 Hy all,
I just found a bug in LPCOpen in the file lcd_17xx_40xx.c, function Chip_LCD_Init(). The clock divider is not computed the right way. The LCD controller use cclk as clock source and not pclk. So the code should be:
