Content originally posted in LPCWare by liaochengyi on Thu Aug 28 23:31:26 MST 2014
Dear Rocketdawg,
Thank you for your answer. :D
I am work on OM13069 Smartphone Quick-Jack solution using the LPC812.
But the size of sample code is about 7KB,
I need add other application, and also need support bootloader.
I think the 16KB flash is too small for the solution, will the NXP have the more bigger flash.
Cost is no problem.
Thank a lot.
Chengyi
