lpcware
LPC800-MAX and UART problem
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Cosik on Thu Feb 27 10:01:00 MST 2014
I just try to run UART on my LPC800-MAX, but it's didn't working. I think that I don't configure or set all necessary registers.
Here are my code:
uint8_t key;
uint32_t clk, i;
uint32_t baudRate = 115200;
const uint32_t UARTCLKDIV = 1;
/* Enable IOCON clock */
LPC_SYSCON->SYSAHBCLKCTRL |= (1 << 18);
/* Setup the clock and reset UART0 */
LPC_SYSCON->SYSAHBCLKCTRL |= (1 << 14)|(1 << 15)|(1 << 16);
LPC_SYSCON->PRESETCTRL &= ~(1 << 3);
LPC_SYSCON->PRESETCTRL |= (1 << 3);
LPC_SYSCON->PRESETCTRL &= ~(1 << 2);
LPC_SYSCON->PRESETCTRL |= (1 << 2);
NVIC_DisableIRQ(UART0_IRQn);
/* Enable the clock to the Switch Matrix */
LPC_SYSCON->SYSAHBCLKCTRL |= (1 << 7);
///* Pin Assign 8 bit Configuration */
///* U0_TXD */
///* U0_RXD */
//LPC_SWM->PINASSIGN0 = 0xffff0004UL;
///* Pin Assign 1 bit Configuration */
///* SWCLK */
///* SWDIO */
///* RESET */
//LPC_SWM->PINENABLE0 = 0xffffffb3UL;
    /* U1_TXD */
    LPC_SWM->PINASSIGN1 = 0xffff0fffUL;
    /* SWCLK */
    /* SWDIO */
    /* RESET */
LPC_SYSCON->UARTCLKDIV = UARTCLKDIV;
/* Configure UART0 */
clk = __MAIN_CLOCK / UARTCLKDIV;
LPC_USART1->CFG |= (1<<2);
LPC_USART1->BRG = clk / 16 / baudRate - 1;
LPC_SYSCON->UARTFRGDIV = 0xFF;
LPC_SYSCON->UARTFRGMULT = (((clk / 16) * (LPC_SYSCON->UARTFRGDIV + 1))
/ (baudRate * (LPC_USART1->BRG + 1)))
- (LPC_SYSCON->UARTFRGDIV + 1);
/* Clear the status bits */
LPC_USART1->STAT = (1<<5) | (1<<11);
/* Enable UART0 */
LPC_USART1->CFG |= (1<<0);
while (1)
for (key = 0x30; key <= 0x40; key++)
/* Wait until we're ready to send */
while (~LPC_USART1->STAT & (1<<2))
LPC_USART1->TXDATA = key;
while (~LPC_USART1->STAT & (1<<3))
Could any one write me what is wrong with my code?
