lpc_chip_8xx_lib release build work not fine.
lpcware
Content originally posted in LPCWare by liaochengyi on Mon Nov 17 06:20:18 MST 2014
Hi, NXP Sirs,
I am working on NXP_Quick_Jack project.
I include the lpc_chip_8xx_lib, when original debug build, it's work fine.
I need more small code size, so rebuild the lpc_chip_8xx_lib to release build.
But, use the lpc_chip_8xx_lib not work fine. It will loss data when receive manchester data.
Will the release build of  lpc_chip_8xx_lib can be modify or fix?
Thanks a lot.
chengyi
