lpcware
New feature: Collapsible sections
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by lpcadmin on Mon Dec 19 15:52:14 MST 2011
You can use the 'collapse' keyword inside square brackets to make a section collapsible.
Use the [ collapse ] identifier to start the section and the [ /collapse] identifier to finish the section.
Un-collapse the section below to see the text.
[collapse collapsed]
You have un-collapsed the section!
[/collapse]
You can use 'collapse collapsed' to make the section collapsed by default.
