Content originally posted in LPCWare by lpcadmin on Thu May 10 09:42:24 MST 2012
Although most content on the site should work fine with Internet Explorer, some issues have been seen when using different versions of IE.
If you are seeing the problems for content that is important to you, you can try using a different web browser (ie, FireFox, Chrome, Opera, etc.)
Noted issues with IE8.
* Some embedded images (PNG) appear as an empty box (ie, placeholder)
Workaround: Use another web browser or verify you are using IE9
* User name and password are not accepted when security level is very high
Workaround: Use another browser or set security to 'Medium high'
Sorry for the inconvenience IE users :(
