Content originally posted in LPCWare by Italia on Wed Jul 30 03:49:11 MST 2014
i wrote this easy code in mt LPC2468 CPU:
Author : $(author)
Version :
Copyright : $(copyright)
Description : $(Module) definition
// TODO: insert include files here
//#include "RFIDREADER.cc"
// TODO: insert other definitions and declarations here
class My_Class
public:
My_Class(void);
unsigned int somma(unsigned int a, unsigned int b);
private:
unsigned int risultato;
My_Class::My_Class(void)
unsigned int i;
for(i=0;i<10;i++)
risultato=somma(i,i);
unsigned int My_Class::somma(unsigned int a, unsigned int b)
return (a+b);
My_Class first;
int main(void) {
// TODO: insert code here
//RFIDReader RF = new RFIDReader;
// force the counter to be placed into memory
volatile static int i = 0 ;
// Enter an infinite loop, just incrementing a counter
while(1)
i++;
return 0 ;
Now, when i put a breakpoint in the for cycle, the degugger never pass in
the cycle, so the object is not initialized. I wont to ask the reason and the possible solution. P.s i already try to define this class in the main loop and
in this case eserithing is well!
