Content originally posted in LPCWare by kwinchell on Tue Mar 26 06:01:06 MST 2013
I am using the Keil uvision SDK 4.60.0.0
I am trying to understand how the USB V0.98 is functioning.
I built the Library for the MCB11U10 board to run the Generic HID Example.
I wanted to step through the process of CALLBACK_HID_Device_CreateHIDReport() getting called.
In the debugging session, I found it gets called by HID_Device_USBTask().
While examining the variables using the Keil debugger, the variables clearly had the wrong values.
After closer examination, I noticed the debugger was using the wrong addresses for the variables.
This initial SP was 0x10000430, and 0x10000400 on entry to HID_Device_USBTask(). Here is what I found:
Variable Debug Adr SP Access Act Adr
ReportId 100003FC SP + 18 10000418
ReportINSize 003F8 SP + 14 10000414
ForceSend 100003F4 SP + 10 10000410
StatesChanged 3F0 SP + 0C 1000040C
It is like the debugger is using the wrong value for its SP.
Any Ideas?
Any Ideas?
I was able to fix the problem be changing the optimization from -O0 to -O1. I just upgraded to Kiel uVision 4.70, but have not tried it yet.
It turns out this issue has nothing to do with the NXP library.
