LPC1114XL and LPC1115XL compatibility
lpcware
Content originally posted in LPCWare by VigneshEP on Wed Aug 13 21:38:06 MST 2014
Are 1114 XL and 1115 XL completely compatible with each other? I mean in terms of power profiles, current consumption, IO drive strengths, address map etc?
I'm looking specifically at LPC1114FBD48/323 and LPC1115FBD48/303.
I went through the datasheet and I could not find any difference. I wonder is there any fine print or errata that I have missed.
Vignesh
lpcware
Content originally posted in LPCWare by VigneshEP on Tue Sep 02 05:05:02 MST 2014
I'm seeing about 50-100 uA of increase in current consumption between 1114 and 1115 for same software, same board. Any clue why it might happen? Flash controller ?
lpcware
Content originally posted in LPCWare by VigneshEP on Mon Aug 25 03:58:56 MST 2014
Thank you. I'm aware of differences in flash size; I was concerned about rest of the specs!
lpcware
Content originally posted in LPCWare by whitecoe on Thu Aug 14 03:52:56 MST 2014
AFAIK they just differ in Flash sizes - 48K vs 64KB.
HTH!
