lpcware
LPC11E37 EEPROM won't write if RAM address is in the 0x20000000 range
Latest reply on Jun 18, 2016 by lpcware
Content originally posted in LPCWare by kcarolan on Fri Mar 11 18:56:35 MST 2016
i mover some of my ram addresses around and I found that I could not write to the EEPROM if the Ram I was using was not in the 0x10000000 range.  Everything worked fine until I change the location of the ram buffer to the 0x20000000 range.
Thanks Kevin
