Steve Huckle
GNU Configure Problems
Discussion created by Steve Huckle on May 15, 2008
Latest reply on May 28, 2008 by leo atreides
I'm having a problem using the MetroWerks CodeWarrior command line compiler under cygwin when trying to build an open source package for the Wii using gnu's configure, make, make install scenario.
Basically, no matter what options I give, when I run configure, I get this far:
configure: error: C preprocessor "mwcceppc.exe" fails sanity check
I realise this is a long shot, but has anyone ever come across this before? If so, could you shed some light on the problem?
Glowy
ps.  mwcceppc.exe -version
Metrowerks C/C++ Compiler for Embedded PowerPC.
Copyright (c) 2006, Freescale Semiconductor, Inc.
All rights reserved.
Version 4.1 build 60831
Runtime Built: Aug 31 2006 18:18:06
