Problem with erase sector..
lpcware
Content originally posted in LPCWare by ElecoLPC on Tue May 10 00:59:38 MST 2016
I'm working on LPC1115, I'm trying to write my boot loader code. The IAP command works well, but if I erase 3 sector (1 to 3)  the uP continue working, but after reset it goes to hard fault handler and PC goes to 0xFFFFFFFE.... WHY?
Thanks.
lpcware
bump
lpcware
Content originally posted in LPCWare by af_bln on Thu May 19 04:41:09 MST 2016
The first 3 sectors may be not necessary for the main code execution and only be needed while start-up.
