lpcware
After adding a Deep Power Down Mode my code stopped functioning
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by lab1 on Fri Apr 04 02:23:34 MST 2014
This is my original code that must switched on and off a diode based ADC value
Chip lpc11c14
#include "chip.h"
int k;
const uint32_t OscRateIn = 12000000;
static ADC_CLOCK_SETUP_T ADCSetup;
static void Init_ADC_PinMux(void)
Chip_IOCON_PinMuxSet(LPC_IOCON, IOCON_PIO1_0, FUNC2);
void Chip_GPIO_Init(LPC_GPIO_T *pGPIO)
Chip_Clock_EnablePeriphClock(SYSCTL_CLOCK_GPIO);
int main(void) {
uint16_t dataADC;
int j;
//Chip_GPIO_Init(LPC_GPIO);
volatile static int h = 0 ;
volatile static int l = 1000 ;
Init_ADC_PinMux();
/* ADC Init */
Chip_ADC_Init(LPC_ADC, &ADCSetup);
Chip_ADC_EnableChannel(LPC_ADC, ADC_CH1, ENABLE);
    while(1) {
    j = 50000;
    while (j--) {
    /* Start A/D conversion */
    Chip_ADC_SetStartMode(LPC_ADC, ADC_START_NOW, ADC_TRIGGERMODE_RISING);
    /* Waiting for A/D conversion complete */
    while (Chip_ADC_ReadStatus(LPC_ADC, ADC_CH1, ADC_DR_DONE_STAT) != SET) {}
    /* Read ADC value */
    Chip_ADC_ReadValue(LPC_ADC, ADC_CH1, &dataADC);
    if (h<dataADC) {
    hoe=dataADC;
    if(l>dataADC){
    l=dataADC;
    if(h>200){
    Chip_GPIO_SetPinDIROutput(LPC_GPIO, 3, 2);
    Chip_GPIO_SetPinDIRInput(LPC_GPIO, 3, 1);
    if(l<200){
    Chip_GPIO_SetPinDIROutput(LPC_GPIO, 3, 1);
    Chip_GPIO_SetPinDIRInput(LPC_GPIO, 3, 2);
    h = 0;
    l = 1000;
So I add this code to use Deep Power Down Mode
LPC_PMU->PCON= (1<<1)|(1<<11);
SCB->SCR|=(1<<2);//Set SLEEPDEEP bit
LPC_SYSCTL->PDRUNCFG &= ~((1<<0) | (1<<1));
__WFI();
This gives me this code
#include "chip.h"
int k;
int main(void) {
uint16_t dataADC;
int j;
Init_ADC_PinMux();
/* ADC Init */
    while(1) {
    j = 50000;
    while (j--) {
    /* Print ADC value */
    if (h<dataADC) {
    hoe=dataADC;
    if(l>dataADC){
    l=dataADC;
    if(h>200){
    if(l<200){
    h = 0;
    l = 1000;
    __WFI();
My problem is that when I added Deep Power Down Mode, the program stops after a passage of my loop.
Does anyone know why this is happening?
