Content originally posted in LPCWare by audriusmerfeldas on Sun Sep 06 12:50:52 MST 2015
I am very new at programming but using examples i am developing me own code. I am trying to set 16 bit timmer for increasing variable 'count' that I am using to display digit on 7 segment indicator. I am trying to get timer interrupt and at that moment increase variable 'count', but now it doesn't seem to work. Please find the code below:
#include "LPC11xx.h" /* LPC11xx definitions */
#include "timer16.h"
#include "clkconfig.h"
#include "gpio.h"
#include <cr_section_macros.h>
#include <NXP/crp.h>
__CRP const unsigned int CRP_WORD = CRP_NO_CRP ;
#define LED_ON 0
#define LED_OFF 1
int main (void) {
GPIOInit();
long count;
// Set port for LED to output
// GPIOSetDir( LED_PORT, LED_BIT, 1 );
GPIOSetDir( 2, 2, 1 );
GPIOSetDir( 0, 7, 1 );
GPIOSetDir( 0, 6, 1 );
GPIOSetDir( 1, 8, 1 );
GPIOSetDir( 3, 1, 1 );
GPIOSetDir( 3, 2, 1 );
GPIOSetDir( 3, 0, 1 );
// Set port for input
// GPIOSetDir( LED_PORT, LED_BIT, 0 );
GPIOSetDir( 1, 10, 0 );
// Initial variable values
count=0;
//Set up 16 bit timer
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<7); //enable clock signal to 16 bit timer0 (sec 3.5.14)
LPC_TMR16B0->PR = 0x0; //set prescaler max value, not used here (sec 18.7.4)
LPC_TMR16B0->MCR = 0x10; //set for reset on counter match (sec 18.7.6)
LPC_TMR16B0->CCR = 0; //set to timer mode (sec 18.7.11)
LPC_TMR16B0->MR1 = 0x64; //set value for period (sec 18.7.7)
LPC_TMR16B0->TCR |= 0x3; //enable and reset counter (sec 18.7.2)
LPC_TMR16B0->TCR &= ~(0x2); //clear reset bit (sec 18.7.2)
while (1) // Loop forever
// 7 SEGMENT INDICATOR CODES FOR DIFFERENT NUMBERS
//1
if (count==1) {
GPIOSetValue( 2, 2, LED_OFF );
GPIOSetValue( 0, 7, LED_OFF );
GPIOSetValue( 0, 6, LED_OFF );
GPIOSetValue( 1, 8, LED_ON );
GPIOSetValue( 3, 0, LED_OFF );
GPIOSetValue( 3, 1, LED_ON );
GPIOSetValue( 3, 2, LED_OFF );
//2
if (count==2) {
GPIOSetValue( 2, 2, LED_ON );
GPIOSetValue( 0, 6, LED_ON );
GPIOSetValue( 3, 0, LED_ON );
GPIOSetValue( 3, 1, LED_OFF );
GPIOSetValue( 3, 2, LED_ON );
//3
if (count==3) {
//4
if (count==4) {
GPIOSetValue( 0, 7, LED_ON );
//5
if (count==5) {
GPIOSetValue( 1, 8, LED_OFF );
//6
if (count==6) {
//7
if (count==7) {
//8
if (count==8) {
//9
if (count==9) {
if (count==10) {count=0;}
//0
if (count==0) {
void TIMER16_0_IRQHandler(void)
if(LPC_TMR16B0->IR & (1<<4)) //capture interrupt?
LPC_TMR16B0->TC = 0; //reset timer
count++;
LPC_TMR16B0->IR |= (1<<4); //reset capture interrupt
} //end capture interrupt
