int main(void) { bool LCD_initialized = false; uint32_t CurrentDisplay = DISPLAY_DEFAULT_MESSAGE; uint8_t LCDmessagebuffer[160]; uint32_t LCDScrollCount = 0; uint32_t i, NDEFmessagelen; extern uint8_t defaultstring[]; uint8_t Buttons = 0; Setup(); } void Setup() { HAL_BSP_BoardInit(); //Board init funtion // Setup Pins on the micro-controller SystemCoreClockUpdate(); /* NVIC is installed inside UARTInit file. */ UARTInit(4800); #if AUTOBAUD_ENABLE LPC_USART->ACR = 0x01<<2; /* Auto Restart, UART mode 0 */ LPC_USART->ACR |= (0x01<<0); /* Start */ while(!UARTAutoBaud ); UARTAutoBaud = 0; UARTSend((uint8_t *)"Auto Baud detected\r\n\r\n", 22); #endif #if MODEM_TEST ModemInit(); #endif print_string("smart meter Reading\r\n"); //Sending Hello string // never leave this function while (1) { __WFE(); } return 0; } //********************************************************************************************************** /* Set up and initialize hardware prior to call to main */ void Board_SystemInit(void) { /* Setup system clocking and muxing */ SystemSetupMuxing(); SystemSetupClocking(); //SetPowerProfile(); } /* Sets up system pin muxing */ STATIC void SystemSetupMuxing(void) { LPC_SYSCTL->SYSAHBCLKCTRL |= (1<<16); //Enable clock FOR IO config. block LPC_IOCON->PIO0[0] = IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGMODE_EN; // RESET pin LPC_IOCON->PIO0[1] = IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGMODE_EN;// ISP pin LPC_IOCON->PIO0[3] = IOCON_FUNC0 | IOCON_MODE_PULLDOWN | IOCON_DIGMODE_EN; // GPIO ... will be VBUS when USB enabled LPC_IOCON->PIO0[4] = IOCON_FUNC1 | IOCON_DIGMODE_EN;// I2C standard mode LPC_IOCON->PIO0[5] = IOCON_FUNC1 | IOCON_DIGMODE_EN; // I2C standard mode LPC_IOCON->PIO0[6] = IOCON_FUNC0 | IOCON_MODE_PULLUP | IOCON_DIGMODE_EN; // GPIO ... will be USB_CONNECT when USB enabled LPC_IOCON->PIO0[7] = IOCON_FUNC0 | IOCON_OPENDRAIN_EN | IOCON_MODE_INACT | IOCON_DIGMODE_EN; // RED LED LPC_IOCON->PIO0[8] = IOCON_FUNC0 | IOCON_OPENDRAIN_EN | IOCON_MODE_INACT | IOCON_DIGMODE_EN; // GREEN LED LPC_IOCON->PIO0[9] = IOCON_FUNC0 | IOCON_OPENDRAIN_EN | IOCON_MODE_INACT | IOCON_DIGMODE_EN; // BLUE LED LPC_IOCON->PIO0[12] = IOCON_FUNC1 | IOCON_MODE_PULLUP | IOCON_DIGMODE_EN; // SW1 LPC_IOCON->PIO0[13] = IOCON_FUNC1 | IOCON_MODE_PULLUP | IOCON_DIGMODE_EN; // SW2 LPC_IOCON->PIO0[14] = IOCON_FUNC1 | IOCON_MODE_PULLUP | IOCON_DIGMODE_EN; // SW3 LPC_IOCON->PIO0[16] = IOCON_FUNC1 | IOCON_ADMODE_EN | IOCON_MODE_INACT | IOCON_FILT_DIS; // Reference voltage: AD5 LPC_IOCON->PIO0[23] = IOCON_FUNC0 | IOCON_DIGMODE_EN | IOCON_MODE_INACT; // VCC_SW LPC_IOCON->PIO1[19] = IOCON_FUNC0 | IOCON_MODE_PULLUP | IOCON_DIGMODE_EN | IOCON_MODE_INACT; // FD input } /* Setup system clocking */ STATIC void SystemSetupClocking(void) { #ifdef WDO Chip_SYSCTL_PowerUp(SYSCTL_POWERDOWN_WDTOSC_PD); LPC_SYSCTL->SYSAHBCLKCTRL |= (1<<15); // enable clock to WDT block Chip_Clock_SetWDTOSC(WDTLFO_OSC_4_60, 2); LPC_WWDT->CLKSEL |= (1<<0); // select watchdog oscillator Chip_Clock_SetMainClockSource(SYSCTL_MAINCLKSRC_WDTOSC); //#else /* the IRC is enabled by default */ //Chip_Clock_SetSysClockDiv(1); #endif Chip_FMC_SetFLASHAccess(FLASHTIM_20MHZ_CPU); SystemCoreClockUpdate(); } void SetPowerProfile(void) { static uint32_t command[4], result[3]; rom = (ROM **)0x1FFF1FF8; #ifdef WDO /* the WDO is running at 4.6 MHz but is divided by two */ /****Call the set_power routine ****/ command[0] = 3;/* Current freq in MHz */ command[1] = PARAM_LOW_CURRENT;/* Use the designated low current power mode */ command[2] = 3;/* Change the set_power */ #elif defined (IRC_4MHZ) /* the IRC is running at 4 MHz */ /****Call the set_power routine ****/ command[0] = 4;/* Current freq in MHz */ command[1] = PARAM_LOW_CURRENT;/* Use the designated low current power mode */ command[2] = 4;/* Change the set_power */ #elif defined(IRC_12MHZ) /* the IRC is running at 12 MHz */ /****Call the set_power routine ****/ command[0] = 12;/* Current freq in MHz */ command[1] = PARAM_LOW_CURRENT;/* Use the designated low current power mode */ command[2] = 12;/* Change the set_power */ #endif (*rom)->pPWRD->set_power(command, result);/*Apply new power profile */ } //*****************************************UART.c********************************************************************************* /***************************************************************************** ** Function name:UARTInit ** ** Descriptions:Initialize UART0 port, setup pin select, **clock, parity, stop bits, FIFO, etc. ** ** parameters:UART baudrate ** Returned value:None ** *****************************************************************************/ void UARTInit(uint32_t baudrate) { #if !AUTOBAUD_ENABLE uint32_t Fdiv; #endif volatile uint32_t regVal; UARTTxEmpty = 1; UARTCount = 0; NVIC_DisableIRQ(UART_IRQn); /* Select only one location from below. */ #if 1 LPC_IOCON->PIO0_18 &= ~0x07; /* UART I/O config */ LPC_IOCON->PIO0_18 |= 0x01; /* UART RXD */ LPC_IOCON->PIO0_19 &= ~0x07; LPC_IOCON->PIO0_19 |= 0x01; /* UART TXD */ #endif #if 0 LPC_IOCON->PIO1_14 &= ~0x07; /* UART I/O config */ LPC_IOCON->PIO1_14 |= 0x03; /* UART RXD */ LPC_IOCON->PIO1_13 &= ~0x07; LPC_IOCON->PIO1_13 |= 0x03; /* UART TXD */ #endif #if 0 LPC_IOCON->PIO1_17 &= ~0x07; /* UART I/O config */ LPC_IOCON->PIO1_17 |= 0x02; /* UART RXD */ LPC_IOCON->PIO1_18 &= ~0x07; LPC_IOCON->PIO1_18 |= 0x02; /* UART TXD */ #endif #if 0 LPC_IOCON->PIO1_26 &= ~0x07; /* UART I/O config */ LPC_IOCON->PIO1_26 |= 0x02; /* UART RXD */ LPC_IOCON->PIO1_27 &= ~0x07; LPC_IOCON->PIO1_27 |= 0x02; /* UART TXD */ #endif /* Enable UART clock */ LPC_SYSCON->SYSAHBCLKCTRL |= (1<<12); LPC_SYSCON->UARTCLKDIV = 0x1; /* divided by 1 */ LPC_USART->LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */ #if !AUTOBAUD_ENABLE #if FDR_CALIBRATION if ( uart_set_divisors(SystemCoreClock/LPC_SYSCON->UARTCLKDIV, baudrate) != TRUE ) { Fdiv = ((SystemCoreClock/LPC_SYSCON->UARTCLKDIV)/16)/baudrate ;/*baud rate */ LPC_USART->DLM = Fdiv / 256; LPC_USART->DLL = Fdiv % 256; LPC_USART->FDR = 0x10;/* Default */ } #else Fdiv = ((SystemCoreClock/LPC_SYSCON->UARTCLKDIV)/16)/baudrate ;/*baud rate */ LPC_USART->DLM = Fdiv / 256; LPC_USART->DLL = Fdiv % 256; LPC_USART->FDR = 0x10;/* Default */ #endif #endif LPC_USART->LCR = 0x03;/* DLAB = 0 */ LPC_USART->FCR = 0x07;/* Enable and reset TX and RX FIFO. */ /* Read to clear the line status. */ regVal = LPC_USART->LSR; /* Ensure a clean start, no data in either TX or RX FIFO. */ while (( LPC_USART->LSR & (LSR_THRE|LSR_TEMT)) != (LSR_THRE|LSR_TEMT) ); while ( LPC_USART->LSR & LSR_RDR ) { regVal = LPC_USART->RBR;/* Dump data from RX FIFO */ } /* Enable the UART Interrupt */ NVIC_EnableIRQ(UART_IRQn); #if TX_INTERRUPT LPC_USART->IER = IER_RBR | IER_THRE | IER_RLS;/* Enable UART interrupt */ #else LPC_USART->IER = IER_RBR | IER_RLS;/* Enable UART interrupt */ #endif #if AUTOBAUD_ENABLE LPC_USART->IER |= IER_ABEO | IER_ABTO; #endif return; } /***************************************************************************** ** Function name:UART_IRQHandler ** ** Descriptions:UART interrupt handler ** ** parameters:None ** Returned value:None ** ** *****************************************************************************/ void UART_IRQHandler(void) { uint8_t IIRValue, LSRValue; uint8_t Dummy = Dummy; IIRValue = LPC_USART->IIR; IIRValue >>= 1;/* skip pending bit in IIR */ IIRValue &= 0x07;/* check bit 1~3, interrupt identification */ if (IIRValue == IIR_RLS)/* Receive Line Status */ //(if interrupt is Available for line status) { LSRValue = LPC_USART->LSR; /* Receive Line Status */ if (LSRValue & (LSR_OE | LSR_PE | LSR_FE | LSR_RXFE | LSR_BI)) { /* There are errors or break interrupt */ /* Read LSR will clear the interrupt */ UARTStatus = LSRValue; Dummy = LPC_USART->RBR;/* Dummy read on RX to clear interrupt, then bail out */ return; } if (LSRValue & LSR_RDR)/* Receive Data Ready */ { /* If no error on RLS, normal ready, save into the data buffer. */ /* Note: read RBR will clear the interrupt */ UARTBuffer[UARTCount++] = LPC_USART->RBR; if (UARTCount == BUFSIZE) { UARTCount = 0;/* buffer overflow */ } } } else if (IIRValue == IIR_RDA)/* Receive Data Available *****************///(Receive complete interrupt) { /* Receive Data Available */ data[count]=LPC_USART->RBR; if( data[count]=='\n') { data[count]=NULL; count=0; print_string(data); print_string("\r\n"); } else { count++; } } else if (IIRValue == IIR_CTI)/* Character timeout indicator */ { /* Character Time-out indicator */ UARTStatus |= 0x100;/* Bit 9 as the CTI error */ } else if (IIRValue == IIR_THRE)/* THRE, transmit holding register empty *************///(interrupt for transmit buff Empty) { /* THRE interrupt */ LSRValue = LPC_USART->LSR;/* Check status in the LSR to see if valid data in U0THR or not */ if (LSRValue & LSR_THRE) { UARTTxEmpty = 1; //if tx buffer is Empty then set the flag! } else { UARTTxEmpty = 0; } } #if AUTOBAUD_ENABLE if (LPC_USART->IIR & IIR_ABEO) /* End of Auto baud */ { LPC_USART->IER &= ~IIR_ABEO; /* clear bit ABEOInt in the IIR by set ABEOIntClr in the ACR register */ LPC_USART->ACR |= IIR_ABEO; UARTAutoBaud = 1; } else if (LPC_USART->IIR & IIR_ABTO)/* Auto baud time out */ { LPC_USART->IER &= ~IIR_ABTO; AutoBaudTimeout = 1; /* clear bit ABTOInt in the IIR by set ABTOIntClr in the ACR register */ LPC_USART->ACR |= IIR_ABTO; } #endif return; } |
