lpcware
ADD out of spec
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by williamjsell on Sat Feb 20 13:55:59 MST 2016
We are using the lpc11u68 device.  Using a function generator generating a triangle wave to test the adc, we see an ~8 count jump every 400 counts or so..  The spec indicates the transfer curve should be between 2-3 counts.  We tested two parts with the same performance.  So the adc performance is down to 2^9 with this 8 count error.  Not very good; anyone else seen this performance?
