problem with nxp lpc 11u24/301: can't open virtual com after running cdc usb rom driver
lpcware
Content originally posted in LPCWare by marcello.ioppolo on Fri Sep 13 02:57:09 MST 2013
hello everybody,
i am experiencing problems with my nxp lpc11u24/301 microcontroller:
i run the usb cdc rom example found at:
http://www.lpcware.com/content/nxpfile/sample-code-bundle-lpc11uxx-peripherals-using-lpcxpresso
on my nxp lpc11u24/301 to let the usb port work as virtual com but after installing the driver provided by nxp support and visualizing correctly the virtual com i cannot open the port with a serial data analyzer or any other software.
i imported the entire usb cdc rom folder and the building is correct and so it is the debugging.
what's wrong with my port?
i use windows xp as os.
thank you very much for your support.
best regards
