lsls r0,r1,#4 ;[1] multiply by structure size add r0,r0,r12 ;[1] add array base address ldm r0,{r0-r3} ;[5] get flags, data-pointer, I/O address and register value str r3,[r2] ;[2] output new value on GPIO pins |
movs r1,#32 rors r0,r0,r1 /* duplicate bit 31 to the carry flag */ adcs r2,r2,r2 /* insert as low bit in r2 */ |
movs r1,#0x5a orrs r1,r1,r0 adds r1,r1,#1 |
subs r1,r0,#1 lsrs r2,r1,#1 orrs r1,r1,r2 adds r1,r1,#1 |
subs r1,r0,#1 orrs r1,r1,lsrs#1 orrs r1,r1,lsrs#2 orrs r1,r1,lsrs#4 adds r1,r1,#1 |
movs r1,#1 ands r1,r1,r0 adds r0,r0,r1 |
LDR R3,=LPC_UART_BASE LDR R2,[R3,LSR] MOVS R1,#0b01000000 ANDS R2,R2,R1 (or TST R2,R1) BEQ/BNE |
LDR R3,=LPC_UART_BASE LDR R2,[R3,LSR] LSRS R2,R2,#7 BCC/BCS |
for(int32_t i = 0; i < 10000; i++){ volatile uint32_t dummy; (void)dummy; } /* the C way */ |
for(int32_t i = 0; i < 10000; i++){ asm volatile("nop"); } /* the "assembler"-way */ |
RSRESET RS.LLLI.srcAddr RS.LLLI.dstAddr RS.LLLI.nextLLI RS.LLLI.control RSENDLLI.size BDRESET;/* I2Sx_DMAx */ BDI2Sx_DMAx_RX_DMAx_ENABLE BDI2Sx_DMAx_TX_DMAx_ENABLE BD,6 BDI2Sx_DMAx_RX_DEPTH_DMAx,4 BD,4 BDI2Sx_DMAx_TX_DEPTH_DMAx,4 ENUMCFG_Transparent,0 ENUMCFG_Blue ENUMCFG_Red ENUMCFG_Magenta ENUMCFG_Green ENUMCFG_MaxColors RSRESET/* GPIO_PORT, General Purpose Input/Output Ports */ RS.BGPIO.B,256/* Byte pin registers port 0 to 5; pins PIOn_0 to PIOn_31 */ RS.L,960/* (reserved) */ RS.LGPIO.W,256/* Word pin registers port 0 to 5 */ RS.L,768/* (reserved) */ RS.LGPIO.DIR,8/* Direction registers port n */ ...... |
PIX. . . . . . . . PIX. . . . . . . . PIX. . X X X X . . PIX. . . . . X X . PIX. . X X X X X . PIX. X X . . X X . PIX. . X X X X X . PIX. . . . . . . . |
dispwrite:PUSH {R4,LR} /* send byte to display */ LDR R3,=LPC_GPIO0_BASE MOVS R4,#1 LSRS R2,R0,#5 ANDS R2,R2,R4 LSLS R1,R2,#6 LSRS R2,R0,#6 ANDS R2,R2,R4 LSLS R2,R2,#7 ORRS R1,R2,R1 MOVS R2,#0b11000000 LSLS R2,R2,#2 STR R1,[R3,R2] LDR R3,=LPC_GPIO1_BASE MOV R2,R0 ANDS R2,R2,R4 LSLS R2,R2,#9 MOVS R1,#1 LSLS R1,R1,#11 STR R2,[R3,R1] LDR R3,=LPC_GPIO2_BASE LSRS R2,R0,#2 ANDS R2,R2,R4 LSLS R1,R2,#4 LSRS R2,R0,#3 ANDS R2,R2,R4 LSLS R2,R2,#5 ORRS R1,R1,R2 LSRS R2,R0,#7 ANDS R2,R2,R4 LSLS R2,R2,#9 ORRS R1,R1,R2 MOVS R2,#0b10001100 LSLS R2,R2,#4 STR R1,[R3,R2] LDR R3,=LPC_GPIO3_BASE LSRS R2,R0,#1 ANDS R2,R2,R4 LSLS R1,R2,#4 LSRS R2,R0,#4 ANDS R2,R2,R4 LSLS R2,R2,#5 ORRS R1,R1,R2 MOVS R2,#0b110000 LSLS R2,R2,#2 STR R1,[R3,R2] LDR R3,=LPC_GPIO0_BASE MOVS R2,#0b1000 STR R2,[R3,#0b100000] /* pulse E */ MOVS R0,#1 BL wait MOVS R2,#0 STR R2,[R3,#0b100000] POP {R4,PC} /* ------------------------------------------------------------------------------------ */ |
