Content originally posted in LPCWare by tswong on Mon Jun 29 04:47:16 MST 2015
I am connecting lpc1114 with eprom 24aa16. My code run perfectly when run line by line, but it encounter hard fault when I just run the program. I am using a switch for different states and a recursion at the end for next state.
switch (stat){
//Master Transmit State
case 0x08://start condition has been transmitted
LPC_I2C->DAT = con_byte;
LPC_I2C->CONSET = I2C_CON_AA;
LPC_I2C->CONCLR = I2C_CON_SI | I2C_CON_STA | I2C_CON_STO;
while(LPC_I2C->STAT == stat);
break;
case 0x18://slave + W has been transmitted, ACK has been received
LPC_I2C->DAT = word_addr;
LPC_I2C->CONCLR = I2C_CON_SI;
break;
case 0x28://DATA has been transmitted, ACK has been received
while(byteCnt != 0){
LPC_I2C->DAT = *data;
data++;
byteCnt--;
LPC_I2C->CONSET = I2C_CON_STO | I2C_CON_AA;
if(case){
e2promStateHandlerNew(rwCtl, con_byte, word_addr, data, byteCnt);
Can anyone figure out the problem?
