lpcware
SSP Slave mode not working
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by dlo on Thu Jan 07 14:36:35 MST 2016
I am using the code example in lpc11xx.keil-examples-CMSIS-update_2 to implement SPI in slave mode. I configured the ssp.h and ssp.c found in the example folder, but can't seem to get data into the receive buffer. I am using a TotalPhase Aadvark USB to SPI controller to send data to the LPC1111. I've tried changing clock speed and set it as Master and do get a clock output on SCK, but do not see data come out.
Thank you for your help.
Original Attachment has been moved to: ssp_0.c.zip
Original Attachment has been moved to: ssp.h.zip
Original Attachment has been moved to: main_19.c.zip
