#include "chip.h" /** * @briefHandle interrupt from State Configurable Timer * @returnNothing */ void SCT0_1_IRQHandler(void) { /* Clear the Interrupt */ volatile uint32_t flag = Chip_SCT_GetEventFlag(LPC_SCT0); if(flag & SCT_EVT_0) { LPC_SCT0->EVFLAG = SCT_EVT_0; //Chip_GPIO_SetPinState(LPC_GPIO, 2, 2, 1);// NECESSARY? } if(flag & SCT_EVT_1) { LPC_SCT0->EVFLAG = SCT_EVT_1; //Chip_GPIO_SetPinState(LPC_GPIO, 2, 2, 0);// NECESSARY? } if(flag & SCT_EVT_3) { LPC_SCT0->EVFLAG = SCT_EVT_3; } } void SCT0_Init(void) { // enable clock for SCT0 Chip_SCT_Init(LPC_SCT0); Chip_IOCON_PinMuxSet(LPC_IOCON, 2, 2, 0x00000083); // PIO2_2 as SCT0_OUT1 Chip_IOCON_PinMuxSet(LPC_IOCON, 1,13, 0x00000082); // PIO1_13 as SCT0_OUT3 // Chip_GPIO_SetPinDIROutput(LPC_GPIO, 2, 2); // Set as output pin - should not be necessary // Chip_GPIO_SetPinDIROutput(LPC_GPIO, 1,13); // Set as output pin - should not be necessary Chip_SCT_Init(LPC_SCT0); // Enable clock for SCT0/1 Chip_SCT_Config(LPC_SCT0, SCT_CONFIG_32BIT_COUNTER | SCT_CONFIG_AUTOLIMIT_L);// two 16-bit timers, clocked internally, auto limit Chip_SCT_SetControl(LPC_SCT0, SCT_CTRL_PRE_L(24)); // Prescaler = 24@Core=48M => SCT clock = 2 MHz Chip_SCT_SetMatchCount (LPC_SCT0, SCT_MATCH_0, 1000); // match 0 @ 10/2MHz = 5 usec (100 KHz PWM freq) Chip_SCT_SetMatchReload(LPC_SCT0, SCT_MATCH_0, 1000); Chip_SCT_SetMatchCount (LPC_SCT0, SCT_MATCH_1, 600); // match 1 used for duty cycle Chip_SCT_SetMatchReload(LPC_SCT0, SCT_MATCH_1, 600); Chip_SCT_SetMatchCount (LPC_SCT0, SCT_MATCH_3, 300); // match 3 used for duty cycle Chip_SCT_SetMatchReload(LPC_SCT0, SCT_MATCH_3, 300); Chip_SCT_EventState(LPC_SCT0, SCT_EVENT_0, ENABLE_STATE0);// event 0 only happens in state 0 Chip_SCT_EventControl(LPC_SCT0, SCT_EVENT_0, (CHIP_SCT_EVENTCTRL_T) ( SCT_EVECTRL_MATCH0 |// related to match 0 SCT_COMBMODE_MATCH|// COMBMODE[13:12] = match condition only SCT_STATELD_1 |// STATELD[14] = STATEV is loaded into state SCT_STATEEV_0 ));// STATEV[15] = 0 Chip_SCT_EventState(LPC_SCT0, SCT_EVENT_1, ENABLE_STATE0);// event 1 only happens in state 0 Chip_SCT_EventControl(LPC_SCT0, SCT_EVENT_1, (CHIP_SCT_EVENTCTRL_T) ( SCT_EVECTRL_MATCH1 |// related to match 1 SCT_COMBMODE_MATCH|// COMBMODE[13:12] = match condition only SCT_STATELD_1 |// STATELD[14] = STATEV is loaded into state SCT_STATEEV_0 )); // STATEV[15] = 0 Chip_SCT_EventState(LPC_SCT0, SCT_EVENT_3, ENABLE_STATE0);// event 3 only happens in state 0 Chip_SCT_EventControl(LPC_SCT0, SCT_EVENT_3, (CHIP_SCT_EVENTCTRL_T) ( SCT_EVECTRL_MATCH1 | // related to match 1 SCT_COMBMODE_MATCH|// COMBMODE[13:12] = match condition only SCT_STATELD_1 |// STATELD[14] = STATEV is loaded into state SCT_STATEEV_0 ));// STATEV[15] = 0 Chip_SCT_SetOutput(LPC_SCT1, SCT_OUTPUT_1, SCT_EVT_0);// event 0 will set SCTx_OUT0 Chip_SCT_ClearOutput(LPC_SCT1, SCT_OUTPUT_1, SCT_EVT_1);// event 1 will clear SCTx_OUT0 Chip_SCT_SetOutput (LPC_SCT0, SCT_OUTPUT_3, SCT_EVT_0);// event 0 will clear SCT_OUT3 Chip_SCT_ClearOutput(LPC_SCT0, SCT_OUTPUT_3, SCT_EVT_3);// event 3 will set SCT_OUT3 /* Enable an Interrupt on the Match Event */ Chip_SCT_EnableEventInt(LPC_SCT0, SCT_EVT_0); Chip_SCT_EnableEventInt(LPC_SCT0, SCT_EVT_1); Chip_SCT_EnableEventInt(LPC_SCT0, SCT_EVT_3); /* Enable the IRQ for the SCT */ NVIC_EnableIRQ(SCT0_1_IRQn); // unhalt it by clearing bit 2 of the CTRL register Chip_SCT_ClearControl(LPC_SCT0, SCT_CTRL_HALT_L); } |
