Hi movax,
Were you able to find the problem? Could you please share what you found?
One time I used gsm development board, and I had to download the code frequently. When I reset and download once, it would work as planned for 5 - 6 times and it would stop working after that. Then I would have to reset and download the code again. I got dissappointed and gave up at one point. A development board cost so much and when they don't work according to your plans, it is frustrating. My guess was that the maker of the board is really cheap and they might have used cheap solder and cheap parts.
<a href="http://www.7pcbassembly.com/prototype-PCB-assembly.php">prototype assembly</a>
