lpcware
NAND Flash support
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by DT1 on Fri Feb 07 07:25:02 MST 2014
I've noticed that in the datasheet and user manuel, external NAND Flash isn't really addressed. It's probably because it's not supported by the LPC4357, but I must ask because that type of memory would help us a lot.
So, would it be possible to connect an external NAND Flash chip to the EMC port (using the dynamic memory type CS because I need large storage) ? If yes, anything to keep an eye out for?
DT1
