Error in User Manual LPC4357 - Rev. 1.9 - Feb 2015
lpcware
Content originally posted in LPCWare by capiman on Wed Jun 24 02:43:37 MST 2015
Page 1248 - Description of Bit TXIE (Bit 11):
11 TXIE Transmit interrupt enable 0 R/W
0 The INTPND bit will be left unchanged after a
successful reception of a frame.
1 INTPND will be set after a successful reception
of a frame.
Description of value 0 and 1 tells something about "reception", but I think must be "transmission"...
lpcware
Content originally posted in LPCWare by capiman on Wed Jul 01 14:30:33 MST 2015
"Page 1256:
When the configuration is completed, MSAGVALis set to valid again."
seems also to be broken (typo).
On same page there is bit TXRQUT, which is never mentioned anywhere else.
lpcware
Content originally posted in LPCWare by nerd herd on Wed Jun 24 08:45:46 MST 2015
Hi capiman,
That certainly does not look right. I will let the documentation team know. Thank you for finding this error!
