Content originally posted in LPCWare by askar on Fri May 02 21:57:52 MST 2014
I know that TI has an Application and program that helps the designers to select their needs around the gpio multiplexers,
when we are designing with LPC4357 with desired package, it is a complicated procedure to select functions on
gpio pins. is there any program like TI program that help designer in using LPC4357?
