* Layer configuration
// Physical display size
#define XSIZE_PHYS 240
#define YSIZE_PHYS 320
// Color conversion
//#define COLOR_CONVERSION GUICC_M565
#define COLOR_CONVERSION GUICC_565
// Buffers / VScreens
#define VRAM_ADDR0x28000000
#define NUM_BUFFERS 1
#define NUM_VSCREENS 1
#define BITSPERPIXEL16
// Display orientation
#define DISPLAY_ORIENTATION 0
//#define DISPLAY_ORIENTATION (GUI_MIRROR_X | GUI_MIRROR_Y)
//#define DISPLAY_ORIENTATION (GUI_SWAP_XY | GUI_MIRROR_Y)
//#define DISPLAY_ORIENTATION (GUI_SWAP_XY | GUI_MIRROR_X)
// Display driver
//#define DISPLAY_DRIVER GUIDRV_LIN_16
#if (DISPLAY_ORIENTATION == (GUI_MIRROR_X))
#define DISPLAY_DRIVER GUIDRV_LIN_OX_16
#elif (DISPLAY_ORIENTATION == (GUI_MIRROR_Y))
#define DISPLAY_DRIVER GUIDRV_LIN_OY_16
#elif (DISPLAY_ORIENTATION == (GUI_MIRROR_X | GUI_MIRROR_Y))
#define DISPLAY_DRIVER GUIDRV_LIN_OXY_16
#elif (DISPLAY_ORIENTATION == (GUI_SWAP_XY))
#define DISPLAY_DRIVER GUIDRV_LIN_OS_16
#elif (DISPLAY_ORIENTATION == (GUI_SWAP_XY | GUI_MIRROR_X))
#define DISPLAY_DRIVER GUIDRV_LIN_OSX_16
#elif (DISPLAY_ORIENTATION == (GUI_SWAP_XY | GUI_MIRROR_Y))
#define DISPLAY_DRIVER GUIDRV_LIN_OSY_16
#else
#endif
// Touch screen
#define USE_TOUCH 0
// Touch screen calibration
#define TOUCH_X_MIN 0x00E0
#define TOUCH_X_MAX 0x0F40
#define TOUCH_Y_MIN 0x00C0
#define TOUCH_Y_MAX 0x0F60
* Configuration checking
#ifndef XSIZE_PHYS
#error Physical X size of display is not defined!
#endif
#ifndef YSIZE_PHYS
#error Physical Y size of display is not defined!
#endif
#ifndef COLOR_CONVERSION
#error Color conversion not defined!
#endif
#ifndef DISPLAY_DRIVER
#error No display driver defined!
#endif
#ifndef NUM_VSCREENS
#else
#if (NUM_VSCREENS <= 0)
#error At least one screeen needs to be defined!
#endif
#endif
#if (NUM_VSCREENS > 1) && (NUM_BUFFERS > 1)
#error Virtual screens and multiple buffers are not allowed!
#endif
#ifndef DISPLAY_ORIENTATION
#endif
#if ((DISPLAY_ORIENTATION & GUI_SWAP_XY) != 0)
#define LANDSCAPE 1
#else
#define LANDSCAPE 0
#endif
#if (LANDSCAPE == 1)
#define WIDTH YSIZE_PHYS /* Screen Width (in pixels) */
#define HEIGHT XSIZE_PHYS /* Screen Hight (in pixels) */
#else
#define WIDTH XSIZE_PHYS /* Screen Width (in pixels) */
#define HEIGHT YSIZE_PHYS /* Screen Hight (in pixels) */
#endif
#if ((DISPLAY_ORIENTATION & GUI_MIRROR_X) != 0)
#define TOUCH_TOP TOUCH_X_MAX
#define TOUCH_BOTTOM TOUCH_X_MIN
#else
#define TOUCH_TOP TOUCH_X_MIN
#define TOUCH_BOTTOM TOUCH_X_MAX
#endif
#if ((DISPLAY_ORIENTATION & GUI_MIRROR_Y) != 0)
#define TOUCH_LEFT TOUCH_Y_MAX
#define TOUCH_RIGHT TOUCH_Y_MIN
#else
#define TOUCH_LEFT TOUCH_Y_MIN
#define TOUCH_RIGHT TOUCH_Y_MAX
#endif
#else
#define TOUCH_LEFT TOUCH_X_MAX
#define TOUCH_RIGHT TOUCH_X_MIN
#else
#define TOUCH_LEFT TOUCH_X_MIN
#define TOUCH_RIGHT TOUCH_X_MAX
#endif
#define TOUCH_TOP TOUCH_Y_MAX
#define TOUCH_BOTTOM TOUCH_Y_MIN
#else
#define TOUCH_TOP TOUCH_Y_MIN
#define TOUCH_BOTTOM TOUCH_Y_MAX
#endif
#endif
#pragma data_alignment=8 // 8 byte align frame buffer
#pragma location="VRAM"
static __no_init U32 _aVRAM[NUM_BUFFERS * NBSP_LCD_VRAM_BUFFER_SIZE_IN_BYTES / (4)];
#define VRAM_ADDR (U32)&_aVRAM[0]
* Driver Port functions
extern void LCD_X_Init(void);
#if (GCONFIG_USE_PROTO_LCD == 0)
extern void LCD_X_Write00_16(U16 c);
extern void LCD_X_Write01_16(U16 c);
#endif
* Private code
static void LCDConf_Delay (int cnt) {
cnt <<= 15;
while (cnt--);
static void wr_reg (U16 reg, U16 dat) {
LCD_X_Write00_16(reg);
LCD_X_Write01_16(dat);
#endif
* _InitController
* Purpose:
* Initializes the display controller
static void _InitController(void) {
#ifndef WIN32
LCD_X_Init();
/* LCD with HX8347-D LCD Controller */
/* Driving ability settings ------------------------------------------------*/
wr_reg(0xEA, 0x00); /* Power control internal used (1) */
wr_reg(0xEB, 0x20); /* Power control internal used (2) */
wr_reg(0xEC, 0x0C); /* Source control internal used (1) */
wr_reg(0xED, 0xC7); /* Source control internal used (2) */
wr_reg(0xE8, 0x38); /* Source output period Normal mode */
wr_reg(0xE9, 0x10); /* Source output period Idle mode */
wr_reg(0xF1, 0x01); /* RGB 18-bit interface ;0x0110 */
wr_reg(0xF2, 0x10);
/* Adjust the Gamma Curve --------------------------------------------------*/
wr_reg(0x40, 0x01);
wr_reg(0x41, 0x00);
wr_reg(0x42, 0x00);
wr_reg(0x43, 0x10);
wr_reg(0x44, 0x0E);
wr_reg(0x45, 0x24);
wr_reg(0x46, 0x04);
wr_reg(0x47, 0x50);
wr_reg(0x48, 0x02);
wr_reg(0x49, 0x13);
wr_reg(0x4A, 0x19);
wr_reg(0x4B, 0x19);
wr_reg(0x4C, 0x16);
wr_reg(0x50, 0x1B);
wr_reg(0x51, 0x31);
wr_reg(0x52, 0x2F);
wr_reg(0x53, 0x3F);
wr_reg(0x54, 0x3F);
wr_reg(0x55, 0x3E);
wr_reg(0x56, 0x2F);
wr_reg(0x57, 0x7B);
wr_reg(0x58, 0x09);
wr_reg(0x59, 0x06);
wr_reg(0x5A, 0x06);
wr_reg(0x5B, 0x0C);
wr_reg(0x5C, 0x1D);
wr_reg(0x5D, 0xCC);
/* Power voltage setting ---------------------------------------------------*/
wr_reg(0x1B, 0x1B);
wr_reg(0x1A, 0x01);
wr_reg(0x24, 0x2F);
wr_reg(0x25, 0x57);
wr_reg(0x23, 0x88);
/* Power on setting --------------------------------------------------------*/
wr_reg(0x18, 0x36); /* Internal oscillator frequency adj */
wr_reg(0x19, 0x01); /* Enable internal oscillator */
wr_reg(0x01, 0x00); /* Normal mode, no scrool */
wr_reg(0x1F, 0x88); /* Power control 6 - DDVDH Off */
LCDConf_Delay(200);
wr_reg(0x1F, 0x82); /* Power control 6 - Step-up: 3 x VCI */
LCDConf_Delay(50);
wr_reg(0x1F, 0x92); /* Power control 6 - Step-up: On */
LCDConf_Delay(50);
wr_reg(0x1F, 0xD2); /* Power control 6 - VCOML active */
LCDConf_Delay(50);
/* Color selection ---------------------------------------------------------*/
wr_reg(0x17, 0x55); /* RGB, System interface: 16 Bit/Pixel*/
wr_reg(0x00, 0x00); /* Scrolling off, no standby */
/* Interface config --------------------------------------------------------*/
wr_reg(0x2F, 0x11); /* LCD Drive: 1-line inversion */
wr_reg(0x31, 0x02); /* Value for SPI: 0x00, RBG: 0x02 */
wr_reg(0x32, 0x00); /* DPL=0, HSPL=0, VSPL=0, EPL=0 */
/* Display on setting ------------------------------------------------------*/
wr_reg(0x28, 0x38); /* PT(0,0) active, VGL/VGL */
LCDConf_Delay(200);
wr_reg(0x28, 0x3C); /* Display active, VGL/VGL */
wr_reg(0x16, 0x00); /* Mem Access Control (MX/Y/V/L,BGR) */
/* Display scrolling settings ----------------------------------------------*/
wr_reg(0x0E, 0x00); /* TFA MSB */
wr_reg(0x0F, 0x00); /* TFA LSB */
wr_reg(0x10, 320 >> 8); /* VSA MSB */
wr_reg(0x11, 320 & 0xFF); /* VSA LSB */
wr_reg(0x12, 0x00); /* BFA MSB */
wr_reg(0x13, 0x00); /* BFA LSB */
#endif
#endif /* WIN32 */
* _SetVRAMAddr
* Purpose:
* Should set the frame buffer base address
static void _SetVRAMAddr(void * pVRAM) {
/* TBD by customer */
* _SetOrg
* Purpose:
* Should set the origin of the display typically by modifying the
* frame buffer base address register
static void _SetOrg(int xPos, int yPos) {
//LPC_LCD->UPBASE = NBSP_SDRAM_GUI_VRAM_ADDR + (xPos * YSIZE_PHYS * PIXEL_WIDTH);
* _SetLUTEntry
* Purpose:
* Should set the desired LUT entry
static void _SetLUTEntry(LCD_COLOR Color, U8 Pos) {
* Public code
* LCD_X_Config
* Purpose:
* Called during the initialization process in order to set up the
* display driver configuration.
void LCD_X_Config(void) {
#if (NUM_BUFFERS > 1)
GUI_MULTIBUF_Config(NUM_BUFFERS);
#endif
// Set display driver and color conversion for 1st layer
GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER, COLOR_CONVERSION, 0, 0);
// Display driver configuration, required for Lin-driver
if (LCD_GetSwapXY()) {
LCD_SetSizeEx (0, YSIZE_PHYS, XSIZE_PHYS);
LCD_SetVSizeEx(0, YSIZE_PHYS * NUM_VSCREENS, XSIZE_PHYS);
} else {
LCD_SetSizeEx (0, XSIZE_PHYS, YSIZE_PHYS);
LCD_SetVSizeEx(0, XSIZE_PHYS, YSIZE_PHYS * NUM_VSCREENS);
LCD_SetVRAMAddrEx(0, (void *)VRAM_ADDR);
#if (USE_TOUCH == 1)
// Set orientation of touch screen
GUI_TOUCH_SetOrientation(DISPLAY_ORIENTATION);
// Calibrate touch screen
GUI_TOUCH_Calibrate(GUI_COORD_X, 0, WIDTH - 1, TOUCH_LEFT, TOUCH_RIGHT);
GUI_TOUCH_Calibrate(GUI_COORD_Y, 0, HEIGHT - 1, TOUCH_TOP, TOUCH_BOTTOM);
#endif
// Set user palette data (only required if no fixed palette is used)
#if defined(PALETTE)
LCD_SetLUTEx(0, PALETTE);
#endif
* LCD_X_DisplayDriver
* Purpose:
* This function is called by the display driver for several purposes.
* To support the according task the routine needs to be adapted to
* the display controller. Please note that the commands marked with
* 'optional' are not cogently required and should only be adapted if
* the display controller supports these features.
* Parameter:
* LayerIndex - Index of layer to be configured
* Cmd - Please refer to the details in the switch statement below
* pData - Pointer to a LCD_X_DATA structure
* Return Value:
* < -1 - Error
* -1 - Command not handled
* 0 - OK
int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData) {
int r;
switch (Cmd) {
// Required
case LCD_X_INITCONTROLLER: {
// Called during the initialization process in order to set up the
// display controller and put it into operation. If the display
// controller is not initialized by any external routine this needs
// to be adapted by the customer...
_InitController();
return 0;
case LCD_X_SETVRAMADDR: {
// Required for setting the address of the video RAM for drivers
// with memory mapped video RAM which is passed in the 'pVRAM' element of p
LCD_X_SETVRAMADDR_INFO * p;
p = (LCD_X_SETVRAMADDR_INFO *)pData;
_SetVRAMAddr(p->pVRAM);
return 0;
case LCD_X_SETORG: {
// Required for setting the display origin which is passed in the 'xPos' and 'yPos' element of p
LCD_X_SETORG_INFO * p;
p = (LCD_X_SETORG_INFO *)pData;
_SetOrg(p->xPos, p->yPos);
return 0;
case LCD_X_SETLUTENTRY: {
// Required for setting a lookup table entry which is passed in the 'Pos' and 'Color' element of p
LCD_X_SETLUTENTRY_INFO * p;
p = (LCD_X_SETLUTENTRY_INFO *)pData;
_SetLUTEntry(p->Color, p->Pos);
return 0;
case LCD_X_SHOWBUFFER: {
LCD_X_SHOWBUFFER_INFO * p;
p = (LCD_X_SHOWBUFFER_INFO *)pData;
// Make the given buffer visible
LPC_LCD->UPBASE = NBSP_SDRAM_GUI_VRAM_ADDR + (NBSP_LCD_VRAM_BUFFER_SIZE_IN_BYTES * p->Index);
// Send a confirmation that the buffer is visible now
GUI_MULTIBUF_Confirm(p->Index);
break;
default:
r = -1;
return r;
/*************************** End of file ****************************/
