Content originally posted in LPCWare by boost on Wed Jan 27 10:45:08 MST 2016
Dear Inspire,
Thanks a lot for your help!.
The example helped me out a lot.
However I ran into another problem. The version of the ROM stack driver is too low. Therefore it only supports up to 4gb.
Is there a way to update this driver? If not, how do i know if a board contains a certain version(without running code on it)?
thank you for your time.
