lpcware
How to start debugging apps in LP4357?
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by jgorsk on Thu Aug 30 01:58:23 MST 2012
I'm trying to use Keil 4.54 (eval) to debug programs in the LPC4357
using only the internal flash and ram memories.
The program loads and the PC is pointing to 0x10403e00 address
instead of a location in the internal flash memory.
The program will not jump or run to main function
but when the PC is altered manually to point to any
funtion in my program, debugging will work (except
for the ISRs).
Is dubbuging in flash based LPC43 parts supported by the current version of Keil?
