The defect at which data transmission in the LPC4330->PC direction stops at present occurs. When it's checked, interruption isn't rising from USB0 at the time of data transmission completion. A rough processing flow is indicated below. ---- [Tx of 330byte data in the LPC4330->PC direction (64 * 5 + 10 byte)] 1) Data is written in Endpoint in BulkIn (EP2) 64 bytes from LPC4330. 2) Data is sent 64 bytes at the timing of BulkIn packet reception from a PC. 3) USB interruption occurs on LPC4330 side by the timing to which ACK to BulkIn transmission data has been returned from a PC. 4) Transmission data of the 64byte continued by USB interruption processing is written in Endpoint in BulkIn.(EP2) 64 bytes. ( 2)-4) is repeated 4 times.) 5) Remaining 10 byte is written in Endpoint in BulkIn (EP2). 6) Data is sent 10 bytes at the timing of BulkIn packet reception from a PC. 7) ACK from a PC to BulkIn transmission data is the timing which has returned, and interruption of USB0 occurs. Transmission processing is completed by the timing. ---- We expect that interruption of USB0 occurs after transmission of 7), but there is a case that interrupt of USB0 doesn't occur by a fixed probability. We want an answer of the following question.
A) We understand as follows. Interruption occurs by the timing which received ACK in USB BulkIn from a PC after data transmission of BulkIn processing from LPC4330. Is this our understanding right? B)Isn't interruption considered as the factor which doesn't occur?
A question related to above. We found the cause point of the issue USB0 interruption doesn't generate.
We are refer to the sample code that available usbhw.c from the above URL. In the process of them seems to be such a factor in missed interrupt has occurred following.
* HighSpeed mode USB * Interrupt source clear ENDPTCOMPLETE is performed after the processing for each Endpoint * In the processing of each Endpoint, take a little time to such memory copy to another bank
So we have modified the process as described in "No.8 Details" sheet. In the modified contents, to perform the processing of each Endpoint interrupt factors from clear at the beginning. We applied this modification, the interrupt missed no longer occurred.
We want to hear your opinion about the following.
1) What is the meaning of the interruption factor clearance which is ENDPTNAK in the original sample code? 2) Is the handle of "Code modification proposal" proper? (Even than missed interrupts can occur in this deal?) -------- The original sample code http://www.lpcware.com/content/nxpfile/lpc4350apdlzip lpc43xx\Examples\USBDEV\Usb_Cdc\usbhw.c : L725 - L750 ''' /* handle completion interrupts */ val = LPC_USB->ENDPTCOMPLETE; if (val) { // LPC_UART1->THR = 'C'; // LPC_UART1->THR = '\n';
LPC_USB->ENDPTNAK = val;<- ??? for (n = 0; n < EP_NUM_MAX / 2; n++) { if (val & (1<<n)) { if (g_drv.USB_P_EP[n]) g_drv.USB_P_EP[n](USB_EVT_OUT);
