Content originally posted in LPCWare by Arjan Kamphuis on Tue Sep 23 07:50:05 MST 2014
I'm trying to resolve the status bit for the time stamp trigger interrupt. As it is not documented in the manual UM10503 v1.8.
Could it be bit 29 of the Ethernet DMA status register? Documentation says the bit is reserved, but it appears to change
on a time stamp interrupt event.
Thanks for your help!
