USB driver on M0
USB driver on M0
lpcware
Content originally posted in LPCWare by khfreiberg on Fri Sep 21 09:46:08 MST 2012
We are using a Hitex 43xx Board rev A4 with LpcUsblib rev 0.95 (Keil).
We try to install USB-device driver for USB0. Everything works fine when running the code on M4. But running the same code on M0 causes problems on PC side. We get errors, the board doesn't get correctly recognized.
We haven't completely debugged the problem at this point. The question is, did we miss anything that need to be considered when running the USB driver on M0?
