lpcware
Max BAUD/transfer rate over USB VCOM?
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by rsp5y on Thu Oct 16 12:44:08 MST 2014
I'm using the USB CDC VCOM library on my Keil MCB4357 board. From what I understand about VCOM, it automatically adjusts its BAUD rate automatically with the host?
For example, if I connect with my host at 115200, the VCOM port will deliver at that rate. If I change this to 230400, it will adjust to that as well.
What is the upper limit on this? ie, how high can I go through VCOM communication on my host application (java app on a PC) before the LPC4357 can no longer keep up?
Thanks for your help!
