Content originally posted in LPCWare by hxxwin2000 on Sun Oct 05 11:27:45 MST 2014hi all,Sorry but my english is very bad!My device:CPU LPC4357 X 1Memory IC: MT48LC4M32B2P X 1Development Environment: IAR 7.20Demand:I need to do an external memory debugging.question:If Run directly ----------> HardFault_Handler,OR Remove options"run to main" ----------> Stopped at the address 0X00000000.address 0X00000000 value of 0X28100800,address 0X00000004 value of 0X280001E1,but,View cpu registers "SP" and "PC" are 0X00000000,Manually modify the SP and PC for 0X28100800 and 0X280001E0 after ,Normal running.Why ?Who can help me fix the problem ?Attach the test program.Thanks in advance!hxxwin2000Original Attachment has been moved to: SDRAMTest.rar
